Switching from LineageOS to iodéOS on an S5e - do I need to re-flash stock first?
Hi, I have a Galaxy Tab S5e currently running LineageOS for MicroG, but I’d like to switch to iodéOS now that there is a build available for this device. I believe the device has the latest firmware from the last update I did before installing LineageOS. Do I need to return to stock first before I go through the iodéOS installation process, or can I proceed directly from LineageOS? Threads such as this one suggest not but I’d like to double check first. Thanks!
@Kai, ich habe 2 Galaxy Tab S5e. Bei Beiden war erst LineageOs oben. Mit TWRP habe ich IodeOs darüberinstalliert. Es gab keine Probleme.
@Kai, I have 2 Galaxy Tab S5e. Both had LineageOs on top first. With TWRP I installed IodeOs on top. There were no problems.
                                                            Translated with Deepl
We also have done it without issues, it should be fine.
But it is not guaranteed that it will always work.
Thanks @Sandy and @tbenoit for your replies. I went ahead with the install straight from LineageOS and have successfully booted into iodéOS. :slight_smile:
