SafetyNet Attestation Failures on Fairphone 6 with iodéOS 7.3
Split from this thread: Multiple Stability and Functional Issues on Fairphone 6
Dear iodéOS Team,
Opening a thread for SafetyNet attestation issues, though I understand this may be discussed elsewhere.
Issue: SafetyNet Attestation Failures
  • Observation: Device fails SafetyNet attestation in microG settings.
  • Impact: Affects app compatibility. For example:
    • Sparkasse “Mobiles Bezahlen” app crashes during payment confirmation
    • Some games may be affected
  • Question: Is this expected behavior? Are there known solutions?
Device: Fairphone 6
iodéOS Version: 7.3
I’m aware this may not be FP6-specific, but wanted to document it for others experiencing similar issues.
SafetyNet was replaced by “Google Play Integrity” and the SafetyNet servers were taken offline by Google last fall. Here is a bit more from a previous post: SafetyNet attestation test failed on iodé 6.6 - #21 by rik
More complete “Play Integrity” would need to come from microG, which would then be available to iodé as well. Currently only “Basic Integrity” is possible. But note that Google changes even make confirming this quite challenging. That post is from one of the core microG devs.
Even without full “Device Integrity”, there are many apps that report they will not work without full “Google Play Services” that do actually work. One of the better places to check is to use Plexus from F-Droid. For example, Mobiles Bezahlen has 2 “Gold” (full functionality) ratings back in August 2025 for microG users of version 7.0.2. But with recent changes to the app it may not be working now as you see.
It really is a bit challenging to reverse-engineer as I suspect you can appreciate. But do take solace that iodéOS has “all the compatiblity” available from microG (and also “a bit more” thanks to signature spoofing and some other parts from ih8sn.
Sorry, the above is maybe a bit to “rambly”…
TL;DR (“too long; didn’t read”):
Please use Plexus, microG issues, and this thread to report non-working apps.
Thank you very much for your reply, I was not aware of Plexus and the other information you provided.
