Thanks for sharing it. It’very interesting.
Xiaomi Mi 10T Lite 5G (=Gauguin =Mi 10i 5G =Redmi Note 9 Pro 5G)
LG V20
Samsung A70
Preferably phones with the 2 SIM cards + dedicated SD or at least 1 SIM + shared SD.
A phone with no SD card just makes zero sense in 2023-2024!
De préférence des téléphones avec 2 cartes SIM ET un port carte SD ou au moins une carte SIM ET un port SD partagé.
Un smartphone sans carte SD n’a aucun sens à l’heure actuelle !
Xperia xz2 ![]()
Xiaomi redmi note 9 pro
Xiaomi redmi note 6pro
Xiaomi Redmi Note 9 Pro (5G) which is a “Gauguin” model, like the Xiaomi Mi 10T Lite 5G and the Mi 10i 5G.
Does this mean that I can use the same packages as for this device?
Pretty sure that’s already supported. See here.
These 3 models are all “Gauguin”. See : Devices | LineageOS Wiki
I was thinking exactly the same thing and it’s interesting to note that the most voted for devices are neither pixel nor oneplus which are undeniably the go to choice for those who want an ‘easy fix’ for FOSS phone. My FOSS phone of choice is the Sony XA2 which did not even make the list but is on the LOS list as a possible 5.0/14.0 candidate so decided to go ahead anyway.
Hi community,
How to push Poco F1 support ?
@Antoine2 who response for new device supporting ?
If Iode developers team has script that will be delete blobs and add Iode modification than i may try to support process for Poco F1
Anybody give me feedback…
Xiaomi 11T Pro ![]()
I’d like to put in a vote for the OnePlus 8T.
Thank you!
Sony Xperia Ace III would be great
From a size standpoint would the Ace would be great but as far as I know it is Japan only and the necessary files for customRoms from Sony aren’t published.
moto g57 power is good
Motorola Moto G75 5G (XT2437-3)
Stock Android 15 | 16, Security Updates 6 years (until 10/2030)
Note: RestlessOS (is an unofficial, unaffiliated fork of GrapheneOS packaged as a Generic System Image). It works for me just like a custom ROM, including Vo5G (5G for voice calls), Wi-Fi calling, 15W wireless charging, charging—offline and online—and 30W TurboPower™ wired charging (Power Delivery 3.0)
Best compact phone that’s supported by LineageOS. Unfortunately IMEI blocked in Australia.
If the new compact OnePlus 15T gets LineageOS support, then I’m voting for that.
Preferably support -fewer- devices -better / more intensively- than the other way around, if resources are scarce. Iodé is the “killer app”, so people (like me) will buy the hardware just to be able to use Iodé.
