Bluetooth doesn’t work since the update to iode 3.0, when I activate it after a boot I get a notification that Bluetooth doesn’t work with the option to close the app. Doesn’t matter what I do, Bluetooth ends up deactivated and deactivates itself every time I try to activate it again.
Any help?
I fixed the issue, clearing the storage data of bluetooth was the solution, I’m not gonna delete the post however if someone has the same problem, maybe my solution works for them too.
Well known issue:
This worked for me too at the time.
