Brace yourself for iodéOS 5 | Préparez-vous pour iodéOS 5 | Mach dich bereit für iodéOS 5
That’s awesome.
Do we have any ETA for the FP5?
Current status 20240227:
v5 available for
FP4
lemonade
cheeta
lynx
panther
Thanks, where did you get this list from?
I thought they would appear in Tags · iodeOS/ota · GitHub
Where are the betas hosted?
I’m god, I know everything :wink:
the stable branch, yes
betas are here:
You do not only know everything, you also are faster than lightning! Thanks!
I am eagerly waiting for the FP5.
Several devices just received a new iodéOS v5 beta : a52sxq axolotl bluejay blueline cheetah flame FP4 FP5 lemonade lemonadep lynx oriole panther pioneer poplar raven redfin.
Users interested in joining the beta group can follow these instructions.
Updated my FP5 to iodeOS 5, everything went well, thanks!
So far I don’t see a lot of changes, some related to “privacy and data” and some to “background” and “lockscreen”.
I’ll open issues if I find something problematic.
You can also join matrix channel
We discuss the issues there, too
Okay, I still need to modify my matrix homeserver to federate.
First issue found: When running the iode Browser and checking the Firewall, it says “Protection disabled”.
When I click on it it tells me:
“App has never used Network and stays unknown.”
Edit:
This happens for most apps. Please note that I am using a Wireguard VPN to tunnel all my requests. Only a few apps appear in the Firewall, like Firefox Beta, Updater. These apps should also use the VPN (but maybe dont?).
Edit 2:
After resetting the Firewall-App all is working again. Maybe it would be good to double-check if this is a common problem.
Edit 3:
Trebuchet crashed and restarted during typing a post on Tusky.
Edit4:
There is a new 5.0 for the FP5, should I download and install that one?
Btw., where is the Beta changelog?
Edit: Probably here? :smiley:
Successfully installed iodeOS 5 on my Pixel 6. Fantastic! Stuff works flawlessly!
Hy,
A link for pool is brocken in french version
Hello
Is there a schedule for release for other phones? I’m interested only in Samsung S9+ for now…
I’ve seen in the announcement that the Samsung 9 series is the exception for the OTA.
My S9+ has /e/ OS T on it so it should be “reset” anyway. Are there any special steps needed for this scenario (/e/ → iode)?
Merci.
Wo bleibt das IodeOs 5 für Samsung S9+? :stuck_out_tongue_winking_eye:
(für viele andere Smartphones gibt es schon die 5.0 seit über 1 Woche)
Where is 5.0 for Samsung S9+? :stuck_out_tongue_winking_eye:
For many others Phones there is published one Week ago.
Thanks, Anna
Correct… it depends on Lineage OS … or is it microg for Lineage OS?
Just some quick extra: the lineagelog site seems to have errors. For Oneplus 5 it says there is no Lineage OS21 support: The selected device is not currently supported in LineageOS 21.0. yet I have installed microg for Lineage OS yesterday on my OP5 so… for sure not an accurate statement.
Yes i’m ready for IodeOS 5 on S9+ :saluting_face::slightly_smiling_face:
On my S9 the OTA update to version 4.11 came last week, so I don’t understand why everyone is talking about a version 5 :thinking:
If a version 5 is really coming up soon, should I bother upgrading from currently installed 4.10 to 4.11 at all?
4.10 is A13 stable
4.11 A13 beta
v5 is A14
There is no LOS A14 for S9 and therefore no v5 for S9
Perfectly clear. thank you.
so if I upgrade to 4.11, I become a Beta tester :thinking: Why doesn’t Iodé set this as an option instead of a default? or did I allow Beta release downloads in my settings? :thinking:
