Apps compatible with iodéOS
WhatsApp (installed from the Aurora Store) is working fine for me, but to get the login verification SMS / call to work I first had to give a LOT of permissions to WhatsApp (SMS, phone, etc). The warning about the custom ROM still exists, but in functionality it did not restrict the login and usage.
There is a bit more discussion on it in this thread.
Editable List: Things change.
A column with the last modified date and Iode Version might be helpful.
Did anyone try out yet whether Google Sheets (table editor) still works under Iodé OS 6.0? It first ran with “Iodé OS 5.8 20241213” which I documented above, it did not work with e.g. Iodé OS 5.7 before.
Note: Although I like the de-googled Iodé OS very much, the “Google Sheets” app is very useful for me to share with friends e.g. a timetable which will be updated from time to time.
Or can someone recommend a comparable open source app and sharing service?
There is a producr called (Collabora Online)[https://www.collaboraonline.com/] whihc dscribes itself as
a powerful online document editing suite available for self-hosting or via trusted partners.
Many NextCould providers integrate it in their app offerings, so you can create and edit documents - including LibreOffice format spreadsheets - online, and share links to them.
I have free-tier accounts with
There is Android app available in F-Droid which allows viewing and basic editing. You can create a new file and save it in the directory on your phone that is synced with your NextCloud host. and create links - ether read-only, or allowing editing.
I too understand your perspective…but want to echo other’s perspectives. Use a web browser first over installing an application. It gives you one more layer of abstraction and if you work it CORRECTLY another layer of privacy. If you want simplicity…install the application - just realize what you are giving up for that simplicity.
Hey !
  1. I also confirm that Revolut application installation is successfull but Revolut account connexion is declined since it detects that OS is not an “Official” Android OS.
    Thus “Compatible” status can be updated to “Not Compatible”.
  2. French bank application “Crédit Mutuel” can be successfully installed and is 100% functionnal. Can be added to the main suuported applications list.
Thanks !
  • The list hit the limit of max allowed characters (32000). Please increase.
  • Should the list be extended by a column for microG requirement?
I was able to add a row to the table just now, not certain if anything was changed but the character limit you mention does not give an error now.
Regarding an additional column for microG requirement, I suggest we don’t do it, as many contributors won’t test with and without microG so it will be inaccurate. I think anyone finds that an app listed as :green_circle: won’t work without microG, then edit the Compatible? column to include both :green_circle: :red_circle: and put a note in the comment column that it won’t function correctly without microG.
Happy to add three apps to the list
App Developer Category Compatible? Comment
Caixadirecta Caixa Geral de Depósitos, SA Banking & finance :green_circle: Aurora Store + Iodé 6.6 + passes SafetyNet
MBWay SIBS FORWARD PAYMENT SOLUTIONS Banking & finance :green_circle: Aurora Store + Iodé 6.6 + passes SafetyNet
EssentalPIM Astonsoft Ltd. Productivity :green_circle: Aurora Store + Iodé 6.6 Pro version purchased with same account is correctly recognized
EssentalPIM, which in itself is not problematic, but happy to announce the “Pro” version previously purchased from Google Play store is correctly recognized when logging in with the same Google account to the Aurora Store.
For those interested it provides a way to locally sync contacts, notes, calendar, tasks and passwords between EssentialPim Windows, an Outlook-like desktop application and an Android device running EssentialPIM Android. It syncs directly over wi-fi, locally without clouds or accounts, and integrates with Android system native contacts and calendar, which are all also working correctly. Can optionally also sync to Google too, but I suspect that won’t be very popular around here.
For any fellow Portuguese folks out there, both Caixadirecta and MBWay financial apps are also working correctly on Iodé 6.6 and Aurora store with spoofing enabled, and pass SafetyNet. These two apps were known for refusing running on custom ROMs in the past, but are currently working correctly.
No manual setup was needed, they just work out of the box.
Tested under a Sony XPeria 1 V running Iodé 6.6.
Hi canard,
do you still manage to work with Bourso with website?
I planned to create a bourso account, but I can use app on iodeOS 6.6 on FP5.
First, I complained because app was not installed from Google Play. Playing with Safetynet, I managed to deal with it, but now, it says that device integrity is not ok.
Bourso website indicates that account creation cannot be done without app. I can used my old ipad to create the account, and if bourso is usable on website after account creation, it could be ok.
hi there. on my case capital banking one app does not work anymore. it does crash. idid reinstall iode os, and same thing happen. it was working fine before.
I am seeing the same issue with the newest version in Auorora (released Aug 1, 2025). But on Google play I see there is an even newer version (released Aug 15, 2025). I’m trying to get the “pre Aug 1” version located. I know it would stop working eventually, but maybe we can hold out on it until hopefully a newer version would work again?
installed Fineco banking app V4.31.1 (709) (Italy) on IodeOS 6.6-20250723-rhode on Motorola G52 from Aurora store.
First I had it under Work profile, unable to get device registration done - bank said wrong code (the one I received via SMS).
Then I installed Fineco app on normal profile, and device registration with new code sent from bank worked fine. App works.
Kind regards
yes. im waiting for.the next capital one update, maybe this fix the problem.
Fortsetzung der Diskussion von (Editable list) Apps compatible with iodéOS:
Hi community!
Today I was able to install and successfully configure the REVOLUT APP on my Brax3 phone. This was not possible earlier on. Obviously there was an update at the Aurora Store or with the App.
There was a fix as part of iodé 6.6 to allow it to work.
Interested to know what the fix was. Please can you link to the relevant GitLab commits?
Thanks.
OK I may take back my comment, looking back I may have had it transposed in my mind with some other components. A SafetyNet fix was applied for v6.6 but nothing specific for Revolut.
I would still be interested to see the fix. I could go trawling the public Iodé repos, but a link might save me some tme :wink:
I am not certain if this is it, but it refers to fixing safety net again :slight_smile: .
I got this by looking at the activity section of the os / lineage (and sub-projects) tree.
For that above commit, it was part of 38 commits all merged together, so the full diff at the time of that merge is here (also clickable from that “activity” list above).
