Apps compatible with iodéOS
Stop this unnecessary discussion! Or open an Off Topic thread instead, but don’t spam all the guys that subscribed to this topic. This shit doesn’t belong in here
Maybe if someone were to fix the ‘Editable List’ editor we would be able to stay on topic. I’ve just tried again and I’m still getting the ‘n-umber n-umber’ error.
The list could be edited my me, just used the dirty fix of replacing all words “nnumber” with “num-ber”
If you folks agree on this I would append this to the “How to edit” section:
  • Please do not write the word “nnumber”. It causes an unknown error. Use “num-ber” instead
this list was essential for my decision to try iode, it has to be updated to reduce frustration.
I think it’s working now. I was just able to update a couple of items for the first time.
Thanks for the heads up. Just added a couple myself.
Hey guys, could someone check if these apps work:
Nucleus Smart, ING, Commbank & Speechify
ING works in microG, ING CommCard does not.
Thanks for the feedback, on the topic of banking, is there an app like the iphone wallet that is capable of storing bank cards? Does google pay work?
Another question does it pretty much work with f-droid/aurora apps or are there still compatibility issues with iodeOS?
The most important app I need to know before buying a phone with iode is the availability of the nucleus smart app? No need to test per se but to see its at least downloadable?
Successfully downloaded and installed from Aurora Store, and run (up to the login / create account screen)
Thanks Pete, I really appreciated it!
Hi–do both Bitwarden password manager & (separately) 2FA/authenticator work?
Sure
Does anyone know if Strike App & Breeze LN wallet are available on IodeOS?
Thanks for the reply! Since iodeOS supports Bitwarden authenticator, if it also supports Strike App & Breeze LN Wallet, I’ll invest in a pro-privacy phone running iodeOS.
Test it and you will see
Strike bitcoin app installs and runs OK up to point where you create an account or log in.
Searching for Breeze LN in Aurora Store finds a ton of apps with the word Breeze in their name, but no exact match. Please give more information about this app
Thanks for the reply! My mistake–I misspelled the LN wallet name. It’s “Breez” (Breez Technology). Good to know Strike App has some problems.
Installs and runs OK
Thanks!
Hi
I installed Iodé 5.8 GSI on a Moto g31 and I find it a marvel both privacy and performance. However, I could not log in WhatsApp (very important for some work issues) as I get the message “You need the official WhatsApp to log in” because it detects a custom ROM. I downloaded the APK directly from the page and it doesn’t work either. Pressing OK and continuing with the login didn’t work either, as I read in some forums.
What can I do, what alternative is there?
In advance I apologize if this is not the appropriate place for this query, but I see that it appears as a compatible application.
Thank you.
