Apps compatible with iodéOS
Thanks.
I did go looking and found a couple of interesting commits in the system_core gitlab repo:
which look a lot like the patch I am currently working with on l4m. But we’re getting off-topic here so we’d best leave it. Thanks for your help.
I have feedback about the app Digitales Amt (or now ID Austria). I have a FP5, the app starts but the id verification (the setup inside the app) fails. It worked fine on CalyxOS two weeks ago.
My configuration:
  • Sony XA2
  • iodeOS 6.6
  • Revolut v10.93
App won’t start: ‘Revolut is not supported on this device…’
What settings did you use in microG?
The same error:
  • Pixel 3a (sargo)
  • iodeOS 6.6
  • Revolut v10.93
Hi community!
Today I was able to install and successfully configure the REVOLUT APP on my Brax3 phone. This was not possible earlier on. Obviously there was an update at the Aurora Store or with the App.
Sorry for late response!
As mentioned device is Brax3, Iode 6.6 (latest version), Revolut v10.93, Iode Standard Protection, MicroG: Location disabeld (no ATM’s), signature deceive disabled, GmS Core installed, Phonesky installed, GSF installed, all on active.
Strange behavior: Not able to put in a new payment method.
Good luck!
On my Brax 3 it worked today also - seams to work - but I am not sure how to use this card with nfc payment
Crédit Agricole banking app “Ma banque” doesn’t work on recent iodé installations.
It requires to subscribe to a payment validation system (“securipass”), which needed a valid safetynet attestation (now deprecated), and now probably need google play integrity (not supported by iodé / microg in its current state).
I suppose many other apps listed as compatible are now affected, too.
Yes I think you are right. Capital One Bank (USA) is in this same category.
Hi. How to add Helios bank app to the list of compatible apps?
Hi there,
just went to IodeOS and installed banking apps
Inbank
Inbank Notify
(Italy)
and works fine from what I can say.
Motorola G52
IodeOS 6.6-20250723-rhode Android 15
Cheers
The table at the top is editable, just click the pencil to the top right when hovering the top of the table. The table editor is a bit cumbersome, try to keep alphabetic!
Hello everyone,
I have iodé phone for several years now and I always managed to work around the apps but I just started my business and cannot make it work with the SumUp app used for handling a payment terminal, did someone ever try to use this service with a iodé phone ?
The app runs normally and I can login to my account but it cannot find the payment terminal via bluetooth for some reason. We tried with another phone and everything runs smoothly so I guess the only difference is the OS. They claim that android minimum version is 10 and my phone says 11 so I should be able to connect in theory.
I tried removing all restrictions for this SumUp app and giving it all permissions but nothing seems to make it be able to see the payment terminal.
Thanks for your help,
Brainstorm
Hello everyone,
Has anyone used the app VR SecureGo plus in the last few weeks? It’s not working for me anymore.
When I open it, I’m redirected straight to the developer’s website, Atruvia (Sicherheitshinweis - Atruvia).
Even the latest app update didn’t change anything. My guess is that the app now recognizes that it is not a certified Android system, especially since the problem also occurs on another iodeOS device here in the family.
Has anyone else had the same experience? And maybe even found a solution to this problem?
My iodeOS 6.8 is not rooted and the bootloader is locked.
I am grateful for any advice.
Cheers
knefl
:germany:
Hallo zusammen,
hat jemand von euch die App VR SecureGo plus in den letzten wenigen Wochen verwendet? Sie funktioniert bei mir nicht mehr.
Wenn ich sie öffne, werde ich direkt auf die Seite des Entwicklers Atruvia (Sicherheitshinweis - Atruvia) weitergeleitet.
Auch das letzte App-Update hat nichts daran verändert.
Meine Vermutung ist, dass die App nun erkennt, dass es sich nicht um ein zertifiziertes Android-System handelt, zumal das Problem auch auf einem anderen iodeOS hier in der Familie auftritt.
Hat jemand von euch die gleichen Erfahrungen gemacht? Und vielleicht auch eine Lösung für dieses Problem?
Mein iodeOS 6.8 ist nicht gerootet und auch der Bootloader ist gelockt.
Ich bin für jeden Hinweis dankbar.
Grüße,
knefl
@knefl
Leider habe ich das selbe Problem. Die Schutzmaßnahmen wurde leider geupdated. Letzte Version die funktioniert ist die 4.1.5 (415004). Über Aurorastore kann man diese Version explizit installieren. Jedoch muss die neue Version erst deinstalliert werden, was den Verlust der Verbindungen mit sich führt. Man muss die Freischaltcodes neu via Brief bestellen.
Thanks for the info about the version number.
Yes, I also feared that this was not a bug, but intentional (protective measures).
This raises several questions for me (to which no one can really give me an answer):
How long will version 4.1.5 (415004) still be usable?
Will the developer Atruvia relax the requirements again?
Will a new version of iodéOS (microg) meet the app’s requirements?
Or should I switch to the offline TAN generator as soon as possible, even though it’s not as convenient to use?
I’ll have to think about that some more…
The “Play integrity api checker” app from the Play Store at least shows that my system does not meet all the requirements. I assume that as long as this is the case, certain apps will also cause problems, right?
:germany:
Danke für die Info mit der Versionsnummer.
Ja, ich habe auch befürchtet, dass es sich hierbei nicht um einen Bug, sondern um Absicht (Schutzmaßnahmen) handelt.
Dabei entstehen für mich gleich mehrere Fragen (auf die mir keiner wirklich eine Antwort geben kann):
Wie lange ist Version 4.1.5 (415004) noch nutzbar?
Wird der Entwickler Atruvia die Anforderungen wieder lockern?
Wird eine neue Version von iodéOS (microg) die Anforderungen der App erfüllen?
Oder sollte ich so schnell wie möglich auf den offline TAN-Generator wechseln, der nicht so bequem in der Handhabe ist?
Da muss ich nochmal in mich gehen…
Die App “Play integrity api checker” aus dem Play store zeigt zumindest auf, dass mein System nicht alle Bedingungen erfüllt. Ich vermute mal, dass solange dies so ist, werden auch bestimmte Apps Problem machen, oder?
im /e/OS Forum gibts dazu auch ein Thread, man wartet auf 4.2.2
Abwarten. Hilft Dir zwar nicht, aber eines meiner Geräte ist gerooted und da läuft das Prg.
Bei mir läst sich die App ohne weiteres starten.
Ich habe sie bisher allerdings nur zum Einrichten von Wero benutzt.
Appversion 4.2.1
IodéOS 6.8
Fairphone 5
Bootloader locked
:england:
Same problem with three devices, unfortunately!
Can we all put pressure on our bank to report this to Atruvia and make it usable again for microG devices? A downgrade is out of the question for me.
:germany:
Selbes Problem hier bei 3 Geräten, leider!
Können wir alle mal Druck machen bei unserer Bank, damit die das an Atruvia melden und für Geräte mit microG wieder nutzbar machen? Ein Downgrade kommt für mich nicht in Frage.
Installed App Version 4.2.3 (423008) via Aurora Store and everything seems to work again. Have to order a new verification code though :face_exhaling:
I can confirm that it works again with version 4.2.3 (423008).
However, Aurora Store does not yet display the new version. So you have to go to “Manual Download” and enter the code mentioned in brackets.
But it works. Let’s see how long that lasts…
:germany:
Ich kann bestätigen, dass es mit Version 4.2.3 (423008) wieder funktioniert.
Allerdings zeigt Aurora Store die neue Version noch nicht an. Man muss also über “Version auswählen” gehen und den genannten Code in Klammern eingeben.
Aber es tut. Mal sehen wie lange noch…
Hi, I added some information about the Tomorrow app (Banking) and the SecureGo Plus app (Banking), but in the process I somehow broke the list. Everything below the Techniker Krankenkasse app lost its formatting and I think there is information loss. I’m unfortunately not able to load the revisions of this post either, it just times out, so I cannot fix my mess. Sorry about that, I hope somebody has the ability to fix this.
Edit: fixed it myself, no info was lost. Apologies! :slight_smile: I think it was related to one of the rows containing an @ - sign, that seems to have messed up things. I manually fixed it.
