Xiaomi 11 T Pro (vili) Unofficial build
Hi there, Sadly my Pixel 6 Pro has died. Is there anyone that would be willing to knock up a build for my backup, and now daily driver, Xiaomi 11 T Pro (vili) ?
Thanks for your time
Cheers
There is no official LineageOS support for this device, so making an IodéOS build would not be straightforward, and is unlikely to happen anytime soon I’m afraid. There is also no official LineageOS for microG build available.
You could try one of the other custom ROMs available for the device in XDA forums. According to this post, the latest unofficial lineage-21.0 build from SourceForge works with microG: that is probably as close as you will get to the IodéOS experience any time soon.
Good luck!
Hi Pete,
Thanks for your reply.
Im currently running an /e/ rom build which is working well. Built by Ronnz98. Also a 2024 build. Hoping for something a little more current.
I do understand though.
Cheers,
Phil
@ronnz98 frequents these forums, and may be able / prepared to make an IodéOS build
Yeah popped the question to him earlier.
Thanks mate
Here you go:
iode-6.5-20250726-vili.zip
Camera app does not work, you need to install another one like open camera
Thanks again @ronnz98 for your great work.
Successfully flashed iode-6.5-20250726-vili ROM. Besides camera, all else works great. Open camera works well and so does GrapheneOS camera.
Nice to be back with IodeOS with my premium account.
Best regards
Update for iode 6.8
iode-6.8-20251004-vili.zip
What are bugs in this build? Thank you
Boot loop for me. Hopefully it will work for you…
Yeah, boot loop on me too :sweat_smile:
Please try this build:
iode-6.8-20251008-vili.zip
iode-6.8-20251008-vili installed succesfully. Setting up over the next couple of hours (Dinner time).
I’ll update you as it happens.
Thanks mate
Edit…So far all is excellent. Nice build thanks Ronald!!
Thank you on this beautiful build. May i know why miui camera not working? Or can we remove it and use aperture instead?
Im using Open camera. Works great.
GrapheneOS camera also works well.
I suppose I took the wrong MIUI apk
Hi
My wife is currently still using the Mi11TPro with the EU ROM. I see that there’s a build available for the device. Since there won’t be any further version updates from the EU ROM, I’ll make a note of it, as I’m using iodeOS on my Mi10TPro as a beta. Thanks in advance for your work on the device.
Update for iode 7.6
iode-7.6-20260622-vili.zip
Sources and install instructions:
https://xdaforums.com/t/rom-official-16-derpfest-xiaomi-11t-pro-vili.4753229/
Thanks Ronald for all you do.
I’ll test this coming weekend and provide feedback.
Cheers
iode-7.6-20260622-vili is working 100% so far.
Android auto also works well.
Thanks @ronnz98 for your work.
Sad that there’s not an official LOS build for this device. Can it be added to the official Iode line up without LOS? @rik @petefoth
Cheers
