x on my phone
Good day everyone,
I would like to kindly enquire about an issue I am currently experiencing.
Over the past few years, I have used Braxos and Linegerieros, and for the last two years I have been using Calyox. However, due to recent issues with Calyox, I have decided to install Iodeos on my phone. I am very pleased with Iodeos, as all my applications, including my banking apps, are functioning correctly.
I have noticed, however, that there seems to be limited support or preference for X. I would like to ask if there is a way to install or use it on my device while running Iodeos.
This functionality worked without issue on the other de-Googled operating systems I previously used, so I am hoping there may be a solution available.
I look forward to your response.
Kind regards,
Well, our list says that X is compatible to iodéOS.
If you provide your device model, other users may assist.
BTW: I love what your translator tool/spell check did to BraxOS (didn’t know that there is one!), LineageOS and CalyxOS :blush::blush: Probably tried to match some Greek names …
Just use nostr instead of X.
@MissPiggy I thought I was just “too prude” to have heard of this one, but I think your brain sorted it out faster than mine :slight_smile:
@jesica please clarify what issues you are facing: it installs fine but some features aren’t working? If so you may want to look at the “Stream” tab in the iodé app (“iodé blocker”), as this may be where the features are getting blocked. You can disable the blocker for X, or you can add customized exceptions if you are a iodé Premium subscriber.
