Some strange thing happened to my galaxy s9 today.
I realized that my WiFi is constantly not connected or more precise, has no internet access. However all other devices in my house are working fine. Even other smartphones.
I restarted several times the phone, the router and also switched WiFi on and of.
Yes, the same with my set up. We use a synology router. Also here,the dhcp works and I can see the device in the network. Actually I even can access the Internet although the phone tells me “no internet”.
Anyone having the same issue?
It is super annoying as I need to deactivate my gsm internet connection and actively connect to this WiFi network in order to use the mobile phone properly.
Maybe I need to load iode fresh and wipe all data once from the phone.
I took a look, and there’s maybe an issue with the NTP server that we use. It may prevent https connectivity test with the captive portal, resulting sometimes in “partial connectivity” and the notification to allow internet. However, I think it should happen only on fresh installations, where the hour is not accurate before the first NTP fix. The NTP server will be changed in next release (ntp.pool.org → 0.ntp.pool.org), and maybe it could solve your issue, although I doubt about it.
Just installed the version 3.0 onto my Galaxy s10 and the wifi iasue is back. I have internet but the signal says no and thus the system is creating some problems.
since yesterday I have the same problem, connected to Wifi, but no Internet through this connection. LAN works fine.
My device is a Sony XZ2 and I use iode 2.4 for a couple weeks now, my router is a AVM Fritzbox .
Connects to other router work fine, I deleted to device on the router, restarted both devices several times.
