Updater crashing
Hi!
After downloading iodé 4.2 on my Fairphone 3 the updater crashes every time I try to install it. Is there a solution?
The updater you try to install ? Which updater ?
I tried to install iodé 4.2 with the updater app of iodé 4.1.
Try to delete the updater storage : long press on Updater icon, App infos, Storage & cache, clear storage.
Thanks, that did the job!
Worked for me too, thank you! :slight_smile:
(The update took really long to install though, I think over an hour)
