I am happly using the Ronnz98 buikd for my S23+.
Kudos Ronnz98, I have a multi year subsciption to iodeOS and when last month I had to change my old supported Samsung A52s I was going to cry.
2 questions,
how can I “pay a coffee” to Ronnz98 ?
Is there going to be any update for the S23 family build?
Je suis en train de l’installer.
Le 23+ n’a pas de sdcard.
Je dois utiliser un USBKEY externe via un adaptateur USBA/USBC et monter la usbkey.
J’ai compris que pour le S23+, TWRP n’est pas capable de décrypter le répertoire data (userspace?) à moin que jé mal compri.
TWRP ne voit pas le répertoire de download .
Je fais un backup avec TWRP sur la usbkey avant
Ciao
PS (Je suis IT mais je vis à Bruxelles 70% et à Brest 30%. un vrais Européen)
Je recommande d’installer via adb Une erreur de vérification peut se produire, mais c’est souvent ok. Si la ROM ne fonctionne pas, installez d’abord la ROM Rising OS et essayez ensuite dirty update iode.
Ok, comme d’habitude jamais le temps pour l’hobby.,
Finalement " adb sideloaded " , ça marche parfaitement.
À quand le 6.2 ?
Merci qua mème.
(Curiosité c’est qua ta lingue maternelle?)
Hello, again from Italy! First of all thank you very much ronnz98 for your work
I’ve just bought a second-hand S23 that unlikely have been updated to the latest version of android. So in this moment it has Android 16, and, for what I read, to install LineageOS Android 15 is needed since the update removed the OEM Unlocking option (I’ve assumed that this is also needed for iodéOS). So I was looking to downgrade, but I’ve red that to do it it’s important that the firmware version that you are going to flash has the same bootloader version of your current one, and mine has the 9th. On https://samfw.com/firmware/SM-S911B I’m not finding any Android 15 version with a security patch level of 9. Is there any possibility that I will be able to flash anything on this phone, or I have to lose any hope?
@ronnz98’s iode-7.5 build is based on AOSP 16, but that won’t do you any good, since your Galaxy S23 SM-(S911B) can no longer be modified after the major Android 16 upgrade. It has been known for months that Samsung prevents bootloader unlocking, particularly starting with Android 16 One UI 8. The most infuriating part, however, is that Samsung touts the A16 upgrade but doesn’t mention a word about the fact that even devices that were previously bootloader-unlocked can no longer be unlocked again.
Hi Ronnz98.
I have noticed a strange behaviour with the 7.5.
Whenever I connect whatever Bluetooth headset I have at home, the phone stops ringing on goes on silence.
I see on the screen the call incoming but no ring neither in the headset not the phone’s speaker.
Any guess why ? @rik , does the ringing work fine for you ?
Sadly I do not seem to be able to roll it back to your 6.8 that was working fine.
I have not succeed downgrading 7.5–> 6.8 - UPDATE - nor 7.5–>6.9
Any suggestion is welcome.- Thanks to all
