Unofficial builds for the Samsung S20 series (S20 LTE, S20 5G, S20+, S20 Ultra) for iode
Unofficial builds for the Samsung S20 series (S20 LTE, S20 5G, S20+, S20 Ultra) for iode 5.2
S20
iode-5.2-20240904-x1s.zip
S20+ (works, I tested it!)
iode-5.2-20240904-y2s.zip
S20 Ultra
iode-5.2-20240904-z3s.zip
iode-5.2-20240904-r8s.zip (S20FE)
As custom recovery you can use:
https://xdaforums.com/t/recovery-unofficial-r12-1-orangefox-for-galaxy-s20-s20-s20-ultra-exynos.4662690/
Latest builds for iode 5.7:
iode-5.7-20241216-x1s.zip
iode-5.7-20241216-y2s.zip
iode-5.7-20241216-z3s.zip
iode-5.7-20241216-r8s.zip
Has anyone managed to successfully flash iode-6.0-20250220-x1s.zip on a Samsung Galaxy S20 (x1s) phone?
I previously had flashed iode-5.7-20241216-x1s.zip without issues, but after flashing iode-6.0-20250220-x1s.zip the phone reaches iodé splash screen and displays it for a while and then it restarts and gets stuck at the same splash screen and nothing happens (I left phone in such state overnight).
So for now I just reverted back to using iode-5.7-20241216-x1s.zip.
Did I do something wrong or is iodé 6.0 (and Android 15) just not compatible with Samsung Galaxy S20 (x1s)?
I apologize in advance if I am hijacking this thread with my post. Any directions to the right place are appreciated if so.
The same also happens with iode-6.1-20250407-x1s.zip.
Look here:
Thank you! I was not aware that there was a separate thread for iodé 6 for Samsung Galaxy S20 series.
custom recovery for S20 FE/S20 FE 5G devices (was linked to in og linked post but I thought I should put it here for the sake of convenience).
https://xdaforums.com/t/unofficial-recovery-orangefox-recovery-project-for-s20-fe-snap-exynos.4439485/
Updates for iode 5.18
iode-5.18-20251126-x1s.zip
iode-5.18-20251126-y2s.zip
iode-5.18-20251126-z3s.zip
iode-5.18-20251126-r8s.zip
S20 is now official in lineageos. What can we do to make Iode ofifcial for s20 series ?
Its official for Lineage23 onward, so if iode 7 is stable someone needs to be ROM Maintainer for this devices
Thank you for your work! How can I help you?
A note: That recovery (orange) didn’t work with the ultra (z3s); I had to use the recovery from LineageOS 19.1.
The iode builds for the Samsung S20 series are a bit outdated. Its official a while for A14 based /e/OS and since The S20 series are officially supported by LOS23 now I did a A16 based port for /e/OS that work. If iode 7 leaves beta I might do builds for the S20 series.
If you like to support me:
https://buymeacoffee.com/ronnz98
Latest S20 builds:
iode-5.18-20251224-x1s.zip
iode-5.18-20251224-y2s.zip
iode-5.18-20251224-z3s.zip
