I don’t have install instructions yet, sorry.
Sources:
I tried the exact steps on Samsung Galaxy S20 (SM-G980F, x1s, Exynos 990 (Exynos 9830)) with both OrangeFox and TWRP and both iode-6.0-20250220-x1s.zip and iode-6.1-20250407-x1s.zip but without any success - flashing was successful, but a while after reaching iodé splash screen phone rebooted and after that it just hangs at the splash screen. iode-5.7-20241216-x1s.zip is working fine. So it seems that iodé 6 (Android 15) is not working on this phone (at least not without some additional tweaking for which I lack knowledge).
Did you install the x1s ROM on a S21?
Oh sorry my mistake. I used 5.10-20250219-arm64_ab on the S 21. So please delete my post above if you can. This is S 20 here.
edit says. I deleted it by myself
I have Samsung Galaxy S20 Ultra 5G and I tried to install Iode twrp > iode-6.1-20250407-z3s.zip then it didn’t work all day is iode nothing else???
I already have davilik/cache also format…
Please help me?
Install latetest iode 5.x version. The 6.x is still in development and not yet working
I tried installing 6.x iode but doesn’t work and where is 5.x install lode? It works or not?
Iode 5 (5.7, I have not tried 5.11 yet, but it should not have issues) works very well on Samsung Galaxy S20 (SM-G980F, x1s).
eOSBuildsRonnz98 - Browse /OtherCustomROMS at SourceForge.net - search for “iode-5” and look for codename of your phone (z3s) in filename.
Worked 5.11 iode but update error. How should I do ??
What do you mean by “update error”?
Thats normal, my unoffical builds have no OTA updates
Please let me know new update
Will post new updates here at the forum
I have 2 ci carrier implants and therefore need Bluetooth for music etc also telephone. Please solve it immediately. Bluetooth crashed and is called cohlear app!!
Please Android 16 Samsung S20 Ultra 5G?
Ha, next step is Android 15 which will take a while…
linieage-21.0-20250517-UNOFFICIAL-z3s.zip Should I install?
If you like the latest Lineage version yes. Sources were not changed so it should work
