Good to see that some “old” Sony phones are (unofficially) supported. Thx a lot!
Question, as i still have a (now unused) XZ Premium: as far as i know this device had the “code name” maple, and not the XZ1 Premium (which does not exist). See e.g. this xda thread. Could you clarify this?
Ah, just read the latest posts in the xda thread - so this is definitely a build for the XZ Premium?
I ran the unofficial LOS 19.x release for a while and had to enable the microg stuff via magisk, lsposed etc., that was not funny so if the build is for XZ Premium, i’ll definitely give it a try. Best way to install? Flash latest stock firmware and the proceed with the “normal” LOS/iode install?
copy iode-4.10-20240223-maple.zip to the SD card or internal memory
install the zip file
OR flash iode-4.10-20240223-UNOFFICIAL-maple-img.zip (or iode-4.10-20240223-UNOFFICIAL-maple_dsds-img.zip) using fastboot fastboot --skip-reboot -w update iode-4.10-20240223-UNOFFICIAL-maple-img.zip
The -w option should format your data partition
hehe… cool! Just checked the stuff i downloaded a while ago; back then i installed twrp-3.6.1-9.0, so i will update that. And then install the ROM via adb sideload, the same way i installed LOS 19.x on that device. Not sure when i’ll find the time, but hopefully the next days or week.
Well, even if an install of the stock ROM is necessary - shouldn’t be a big problem, still have the files and the doc i’v written…
Not sure if that is releveant… so installed stock ROM, re-enabled everything and flashed the twrp, this time with the twrp.img in the fastboot folder (not sure if that is relevant). Then boot into twrp, sideloaded the zip and restartet the system … crossed some fingers … system started!
There’s a message in the top menu bar (the one with time, wifi status and battery icon):
Sony Modem
Status: 0
Config: amss_fsg_maple_telekom_germany_volte_vowifi_tar.mbn
Cust ID: N/A
Not sure, but maybe because there’s no SIM card in it?
Next: update apps. Checked f-droid, updated paket sources → at the first try i got a DNS resolution error (couldn’t resolve one host), although wifi was active. 2nd try was good, sources and then iode browser got updated.
Next: Aurora store. Runs, was able to install and start 3 apps (outdooractive, postident, firefox). Looks good.
Iode App is running. Dito iode news app.
So far, so good. Is there something i should test?
OK here’s an Iodé 5.1 build for maple & maple_dsds only. I didn’t build for poplar_dsds, as there were zero downloads of the 4.10 build. (There were zero builds for maple also, but I built it by mistake. If there are now downloads in the next couple of weeks, I’ll delete it to save space on SourceForge.)
Thank you for poplar_dsds adapted to the rom, I found that there was a new update yesterday, and I was wondering if it is supported to use the latest kernelsu root mode。
No. The only support for root is that rooted debugging (adb root) can be enables in Deveoper options. I have no need or desire to root my phones, and I believe there are third-party root solutions available for those who do want to
My XZ1 dsds now fails to see any inserted SIM card. I tried reinstalling the build to no effect. Must be a hardware failure. (I have dropped it a couple of times recently.) Guess I’ll either pay a shop to replace the SIM apparatus, or just repurpose the device.
