Motorola moto g84 5G (bangkk) for iode 7.1
Please see sources and install instructions including recovery here:
This device is officially supported by LineageOS.
Use it at your own risk!
Please support the developer(s)!
Good to have you making this one @ronnz98 I know that it is quite a popular one judging from the LineageOS for microG download stats.
The installation of iode-6.6-20250803-bangkk by @roonz98 was successful. An OTA update function is missing, but if the “Local update” worked, an OTA option could be safely dispensed with.
iode-7.x-2026*-bangkk could be tested by me as soon as a version iode-7.2-2026*-bangkk or higher is released.
Hi @ronnz98, many thanks for this build! Installation went fine, after I realized that the build date for boot.img, dtbo.img and/or vendor_boot.img has to be older than the one from your build. Otherwise, there was an error like "installation aborted…would be a downgrade” (not sure).
But everything on the moto g84 works great, it seems till now!
Yes, similar than here:
Hi @ronnz98 is there an update for the moto g84? 7.1 still runningg great and the phone has a great battery life. Thanks!
Update for iode 7.3
iode-7.3-20260321-bangkk.zip
bangkk
Firmware (A15) XT2347-2_BANGKK_RETEU_15_V1TCS35H.88-16-1
Installation of iodineOS 7.1 without any problems
No OTA update available
Update via “Local update” = " Failed to import local update" iode-7.3-20260321-bangkk.zip by @ronnz98
Alternative A16 ROMs with OTA-Update supoort
Note: This add-on needs to be installed before booting into LineageOS for the first time!
Update for iode 7.5
https://sourceforge.net/projects/eosbuildsronnz98/files/OtherCustomROMS/iode/iode-7.5-20260604-bangkk.zip/download
I could build now, this was an easy fix
Thank you so much, @ronnz98 !!
I did miss the updates in this thread, sorry. Now I’ve updated to 7.5 yesterday by local update in the updater app. No problems, everything works! Good job.
hiya all, im getting a SPL downgrade level… could someone who has the 20260604 bangkk image files please show me how to get them? thanks for everything in advance! @ronnz98 also are you working on an update to this? neat if you are! Have a great day!
Update for iode 7.7
Heyy! I’ve got a very “unusual” phone called the Cubot KingKong Power 5. I tried installing iodéOS, but I failed again and again. The phone also has some system apps and a dedicated button for the flashlight.
If you could make a version of iodéOS that supports those two functions and runs properly on this phone, I would be incredibly grateful!
Have a great day! And if you can’t, that’s totally okay. You’re still doing great work helping the community!
is it becoming official any time soon?
No, unfortunately there are no plans for that, even though this is indeed quite a popular device.
Maybe I can help with that? However I dont have the device myself
With an avb_custom_key-bangkk.bin even the bootloader of the Motorola moto g84 5G can be relocked, as a recent other Android A16 distribution in practice demonstrates – including OTA update.
I have a g84 but with calyx and bootloader relocked.
update for iode 7.8
The external designation «iode-7.8-20260926-bangkk.zip» is corrected by the internal ROM designation «iode-7.8-20260926-UNOFFICIAL-bangkk»
OTA update support is neither continuously nor sporadically available, nor is the “relocking bootloader” option available.
For me personally, the lack of OTA update support is not a handicap, but for the “average user” it is.
