I’m going to give this mod’ a go when I get back from holiday. I’ve got an XZ1 I was given about a year ago by a friend of mine who understands my passion for Sony’s, or obsession with ‘art deco’ phones as my partner prefers to tease me with. The phone looks a little tired and also appears to have a battery or maybe USB/charging port board problem. Never really looked at it but might just spend a few quid on ebay to sort it out.
Would be worth it just for the play I’m thinking. If it works out I’ll treat the phone to a new screen and rear panel.
It’s a compact for sure Pete and it was more a friend of my partner’s that gave it to me TBH, consequently it’s in a rather nauseating shade of Inyerface Pink. Hence the reason it has stayed in my drawer for a while and probably the real reason as to why I might treat it to a new case. It does have that used and abused look about it even though everything still appears to work ok, so long as you have it plugged in to a power source.
Sony sold an awful lot of these to women that wanted something a little more discreet than the kind of phones you could paddle a canoe with that manufacturers seem to prefer to make today. After Sony’s ‘art deco’ renaissance period I lost interest in their products and everyone else’s too come to think of it.
Great! Happy that you could recover it! I still wonder what happened? I didn’t do anything, didn’t swap Sim or anything. Just yesterday it stopped working.
Newflasher is a tool available at XDA to flash Sony stock ROM. you use it in download mode of the phone. the download mode is started when the phone is switched off,keep VOLUME UP pressed and connect an USB cable. The green led should be shining. then, newflasher can be used as explained in the XDA thread.
TWRP 3.7 official is necessary to format data of the Sony stock ROM with android 9. However, that twrp version is not compatible with modern Android 14 Roms. so, you then need to flash TWRP 3.6.2 by Yoshino and from there you use adb side load for e.g. iodeos.
Why this complicated workflow? if you flash directly TWRP 3.6.2, it cannot decrypt the data partition from the Sony ROM and you get stuck at the splash screen.
Spent a little time yesterday on ebay looking for XZ1 parts and just happened to come across an interesting scam involving cheap refurbished Chinese G8441 phones and motherboards. Relevance to the thread is tenuous I know, but to anyone thinking of buying a ‘refurbished’ XZ1 phone or motherboard it’s essential reading. Buyer beware! It’s also an interesting read as to how they have managed to do it despite the lack of functionality in the final product.
thank you so much, I will bookmark this and try it out if it ever happens again! Would be nice to fix it without re-flashing stock ROM and recoverying everything. That was about 3h work.
This morning I had again the same problem. No SIM then white screen etc…
So I tried your link, which I saw, by the way, the first time it happened but I didn’t dare to try it, stupid I am, because it worked !!!
Thanks a lot
To be accurate, Docomo phones aren’t Chinese, they’re Japanese. Docomo’s a Japanese mobile phone operator that, for whatever reason, prefers deeply to customize phones, even to the model number (i.e., SO-02K rather than G8441). Used XZ1c exemplars (just as with the XZ2c) are cheap when they’re Docomo, and not cheap otherwise, because the former are useless for aftermarket ROMs.
Sony Xperia ZX1 Compact (lilac), released in fall 2017, was delivered from the factory with Stock Android™ 8.0 (Oreo) and only received an upgrade to Android 9.0 (Pie). At best, it will run with a 9-pie GSI, perhaps with a 10-Q GSI, but not at all with an 14-U GSI.
I did get an unofficial /e/OS Android 9 / pie GSI on my XZ1 Compact. See here and here. Most things just about worked, but for my daily driver at the time I moved on to a device-specific Pie build of HavocOS, where everything I needed and wanted to do worked fine
I tried several Android 10 / Q GSIs, including an unofficial /e/OS GSI (from the same developer wh made the working Pie /e/OS GSI), and phhusson’s [AOSP 10.0] [2019-12-06] Quack Phh-Treble GSI from here , but they all bootlooped.
So I would definitely recommend using an up-to-date unofficial device-specific build of this device. It will run much better, and do significantky more than any GSI. Android 21 / lineage-21 device-specific builds are available for
