It seemed to me automatic updates were not happening for Aurora and ioDroid.
I decided then to uninstall Aurora and ioDroid, using the Preinstalled App menu in Parameter settings.
They did uninstall but I am not able to install them again. The preinstalled app menu shows them as install but I can find them neither in the application list of Settings nor on the launcher.
It is proposed to update when I try to install but the install button remains. I see now the apps in the Settings>Applications menu but I don’t find them on the launcher. So, I can’t launch any of them.
FP5 is the one that has an occasional issue with “Preinstalled Apps confusion” which hasn’t been resolved or able to reproduced by our lead developer.
First a question: after your “preinstalled apps uninstall” did you reboot? And then again did you reboot after “preinstalled apps install”?
If so, then it must be related to this bug I note, if you read farther down the thread you link I got feedback from Vincent (lead dev) to reset your iodé app custom settings… There are a few extra comments there about making sure to “uninstall updates” to the ioDroid app, etc. that may be adding to the confusion.
Thanks for passing along. Additional information: despite I was on iode7.7, I had the old version of the updater. I just noticed while installing the Updater again, from the APK.
I still have issues with the Pre-installed App module on iode7.8
