I had to remove my backup settings in Seedvault.
Now I cannot add my WebDAV mount anymore. It doesn’t come up. It says “WebDAV mount not available. Set one up” But it is set up in DAVx5. I can also access it through Files.
Has anyone else experienced this?
I wonder if this is related to this issue? Mounted drives not available in some apps
Anyone else using a WebDAV mount for Seedvault? Hoping we can get some more feedback.
Good morning
I too used DavX for seedvault before but recently I have been using access directly in seedvault via webdav because the option is no longer available. Maybe a DavX update?
Registering WebDAV providers directly with “WebDAV Cloud (Beta)” works. The DAVx option no longer works for me either.
The problem is that I cannot use my Synology NAS for backup via WebDAV through WebDAV Cloud (Beta) because it doesn’t accept self-signed certificates and DAVx does.
“Security and convenience remain bitter enemies” ![]()
I personally consider them intimate lovers that are desperately seeking ways to understand each other but forever fail to do so.
