Repo sync stuck
I am experiencing a similar yet not identical problem described here: Repo sync stuck: Host key verification failed
Multiple attemts - even from scratch: Always yielding the idenatical result that I fail to download the sources for builing iodeos. Status unchanged since about a week.
It always stops at the same point:
The authenticity of host 'gitlab.com (2606:4700:90:0:f22e:fbec:5bed:a9b9)' can't be established.neage/sepolicy
ED25519 key fingerprint is SHA256:eUXGGm1YGsMAS7vkcx6JOJdOGHPem5gQp4taiCfCLB8.
This key is not known by any other names
Fetching: 74% (916/1235) 2:26:44 | 20 jobs | 12:26:42 lineage/device_lineage_sepolicy @ device/lineage/sepolicy
The complaints about the unestablished authenticity of host gitlab.com start right in the beginning. However, download continues up to exactly 74% and then sits there forever.
I do not see a corresponding entry in my ~/.ssh/known_hosts.
Does anyone know how to interpret these messages - ideally with a hint on how to get past this point so I can create a build for iode 4.7?
Comments and suggestions will be greatly appreciated.
That’s fixed, you can sync again.
