No mobile data exept textmessages
Hallo, since some days my mobile data doesn´t work anymore although I have still reserves. Only textmessages can be sent and recieved…
what could be the reason for that?
Thanks for your help!
Please check these settings:
  • System Settings > Network & internet > SIMs > Mobile data is active?
  • System Settings > Network & internet > SIMs > (your sim) > Access Point Names shows your carrier’s correct APN entry and it is enabled?
If still not working, please clarify device and your cell provider (and country) so we can better help
Hallo and thanks for your reaction. Mobile data is activ and APN is correct.
The problem changed: at the moment it is only telegramm, which can´t load videos and pictures. Also I can´t open Links from telegramm. The normal browser works…
It is a Samsung Galaxy S10, Fonic (Lidl mobile / O2), Germany
Let’s continue on the telegram issue on your other thread, since this doesn’t seem (directly) related to mobile data connectivity.
Thank you!
Have you a VPN running?
Really closed telegram an reopened it?
Are there some entries in the iodé app?
Thank you. I don´t know why and how, but meanwhile it works again…
As with the other thread, even though we didn’t get a clear understanding of the problem could you mark it as solved?
