Messed up upgrade to Android 16
Ran installation without first upgrading the installer. Question: Will the system upgrade be ok with next update after 6.10?
Which version are you on now? Does that version work?
Thank you, it works OK but I am still at Android 15. Iode is 6.10
I didn’t even know that there was a version 6.10 :grin:
I’d suggest you do the updater-thing as instructed here in the forum or in the iodé news app and then do the proper update to 7.0 (this will bring Android 16).
But I am not as experienced with all that installation stuff, @rik will for sure know more.
Never forget to do a data backup before installing anything …
Not all devices are upgraded to v7. Maybe some of them will never be upgraded. The actual list is in the first post here : iodéOS v7.0 upgrade: important information
