I’m coming here from FP5 Bootloader relock - #5 by ichich – after I updated to the iode 7.8 beta version which allowed me to relock my bootloader.
So I relocked the bootloader which worked fine, my phone still boots and it also shows that correctly on fastboot oem device-info.
However, now I’m getting the message “Your device is loading a different operating system" just like Any way to avoid your phone has loaded a different operating system?
It seems it’s not possible to avoid this, which is not optimal but ok for me.
I would like to know whether I can safely disable “allow OEM unlocking” in Android’s (i.e. iode’s) developer settings? Is that fine or is it possible to brick the phone?
Sorry if this is a stupid question, but I really don’t want to brick my phone (and I never flashed a ROM before).
It seems to me that if I keep that enabled, it’s basically useless to have a locked bootloader as you can just boot into fastboot and unlock the bootloader from there. So to get the better security I should disable that in iodeOS, right?
(If I disable the option now and it breaks, afaik I will not be able to unlock the bootloader again, i.e. it would be bricked then)
Thanks!
