Is there a reliable way to install iode on a Fairphone 4?
I’ve read about some people who bricked their device and now I’m not sure if I should install it or not.
I believe there is always a little bit of risk, but I don’t want to brick my device.
Thanks!
I had exactly the same concerns as you and wrote a blog post about it:
Maybe that helps to get a better feeling of what are the risks associated. I would claim that, if you follow these detailed instructions closely, there is very little risk to brick your device.
