But, how to use adb, sideload, recovery (twrp) can not be part of that.
If you don’t know anything about that, then a step by step guide is not the solution. It cannot go into that deep, if no knowledge is available by the user.
It’s on you to read and learn about all of these topics first.
To many prerequisites…
Hi all, I would like to flash latest version of the iodèOS onto my mi9.
I don’t know what miui base is required, if it’s needed to remove encription and other things.
An installation guide would be welcome, thanks
Hello @ceppy,
the iodé forum is still well manageable and therefore posts are relatively easy to find - if you use the Search option (top right - magnifying glass). If you use this, you will immediately find the thread How to install IodeOS on Xiaomi Mi9? (need a clear guide). A link there branches to the website of iode.tech, etc… So as a welcome, here is the official guide of the iode.tech team, extended a little bit by me.
Thank you for the reply. I saw that thread but it’s referred to iodè 1.x which is currently running in my phone.
Latest stock firmware is 12.5.6.0 RFACNXM but it’s a China fw, not an EEA.
I never flashed a non EEA fw before so this creates doubts to me.
Also almost all android 12 roms require an encription removal because twrp can’t decript them.
Got a working installation but now can’t get root.
Tried to sideload magisk.zip, booting twrp from fastboot and patching boot.img from magisk app then flashing it from fastboot…no luck
edit: even patching iodè recovery with magisk app doesn’t work
