Hey all,
I upgraded to iodé 6.6 a few days ago, and noticed a couple of quite important regressions:
- The earpiece and loudspeaker stopped working
Bluetooth sound is okay, but I don’t have sound otherwise. This sometimes happened pre-6.6 too, but a reboot usually made sound work again. Now, sound is just permanently broken.
- The iodé app/traffic blocker stopped intercepting traffic, and required a data reset
The iodé app didn’t detect any installed app on the phone, and thus intercepted no traffic. The “report” tab showed no traffic, the “stream” tab showed a loading wheel. I had to use the “data reset” button in the settings tab for the application to resume working. While I think this is intended, the data reset also caused the iodé app to forget which apps I had set up to be reinforced blocking, and which to standard blocking.
Anyone else seen this? And is this the right channel to raise the issue to the dev team?
Cheers!
