Hey all,
(spun off from this thread)
As another regression on upgrading iodé OS from 6.5 to 6.6 from the updater app, the iodé app/traffic blocker stopped intercepting traffic, and required a data reset.
The iodé app didn’t detect any installed app on the phone, and thus intercepted no traffic. The “report” tab showed no traffic, the “stream” tab showed a loading wheel. I had to use the “data reset” button in the settings tab for the application to resume working. The data reset also caused the iodé app to forget which apps I had set up to be reinforced blocking, and which to standard blocking. While I think this may be intended behaviour, it is still a minor annoyance.
Has anyone else noticed this?
Cheers!
