samsung a5 sm a520f
up + home + power → wipe data/factory reset → yes
returns
wiping data
formatting /data
formatting /cashe
data wipe complete
e:failed to clear bcb message failed to find /misc partition
The factory reset does not work. Is there another option to factory reset the phone? Android is installed on the phone. I got the phone used and do not know the pin. Thank you.
