I currently run Android 15 on my Pixel 9, it seems that the updater cannot do the next upgrades and I will need to do it manually.
Does doing this force a full system wipe or can I preserve my data and installed apps somehow?
See here if it is an upgrade from iodé 6 to iodé 7:
Versions above 6.9 do not require the 6 to 7 updater.
Thanks, I will try it now. ![]()
