Couple of issues on Devon(Moto g32); 1) Brightness issue & 2) Bootloop issue(hard reboot)
i would like to report couple of bugs on Devon(iodeos 6.4) since i couldn’t access iode’s gitlab. And since im new to iode too.
The bugs are
  1. Brightness issue: this one (Brightness Slider Curve is Messed Up on A15 6.7.23 (#3262) · Issues · CalyxOS / calyxos · GitLab) I think Calyx Team have fix this issue on CalyxOS
  2. And Bootloop issue: when you plug in wired head phones and then restart/reboot the device the bootloop(hard reboot) occurs until you unplug it.
    This issue occurs on CalyxOS too, probably on LineageOS too haven’t test it though (Whatsapp and headset causes reboot on call (#3240) · Issues · CalyxOS / calyxos · GitLab)
Update: Solved via update(iodeOS 7.0)
Can you clarify if both issues are now solved?
Update: I see this separate post, so we can followup on brightness there: Auto-Brightness Issue on Devon(Moto G32 iodeOS 6.9)
Sure,
  1. Before 7.0(i.e., 6.8 or 6.9) i have to put brightness at 30% atleast to be able to see the screen otherwise it is too dark to see the screen even during night time but now the issue is resolved(i put 0 to 2 % and i can see easily as on moto g32 stock Android )
  2. I put a headphone and reboot the device, it soft-reboot into bootloop over and over again but now it doesnot give anymore bootloop problems
Note: this post is different from the one you pointed out and which i posted. This one is related to brightness issue and bootloop and the other about *auto-brightness functioning in sunlight* even when auto-brightness feature is off
