I have some issue in iode and this is this the right place?
Got the Brax3 phone
Updated iode to latest version 6.6 and having an working wifi connection.
The mobile data connection have some issue, only telegram works and can access internet via mobile data. all other apps can’t connect via mobile data.
I have restored the iode to a fresh install and still no mobile-data connection for the other apps.
When switching to wifi, all apps have working internet and it works fine.
Sweden > With carrier Fello(Telia)
An other thing i notice
In Settings>battery>batteryinformation
My battery-information on iode reports
Design capacity 496 mAh
Maximum capacity 4964 mAh (1000%)
When battery is 100% there are no space left to show the last digit for the clook
System Settings > Network & internet > SIMs > (your sim) > Access Point Names
shows your carrier’s correct APN entry and it is enabled?
The solution was to set APN. ( no APN where selected, i think)
Should have checked that before making post
little wierd that Telegram could send messages.
It looks like you have extra widgets showing your up/down network speeds, this combined with also showing battery % is just too much to fit My preference is to change the battery status indicator to a circle, it is much easier to glance at to show about how much is used / remaining (and then you swipe down your notification bar to see full % if needed, but I find it unnecessary)
