I use IodéOS starting from the version 1.4 and I’m extremely happy with it!
I received a BlackView Shark 8 as a gift with Helio G99 processor.Does anyone know if it is possible to install iodéos?
And if it weren’t possible, is there the possibility to install any lineageos version?
@emilioraim: instructions for the GSI can be found here: What are GSIs and how to install them? - iodé
check if it is treble compatible using adb: adb shell getprop ro.treble.enabled
if it returns true, you can install a GSI, people are having lots of success. If you get it working, please let us know in this thread: (Editable list) GSI support
keep in mind that GSIs do not receive critical updates to firmware, as the device drivers no longer get updated
Greetings,
The installation of the GSI iodé-5.7-20241117-Arm64_AB.IMG.XZ in Stark 8 was successful.
However, a big problem is presented: the audio reception of telephone calls is almost impossible. The audio is continuously interrupted, he feels like the hobborn voice.
I don’t know if it is only relative to my phone. With others OS I know, however, it works correctly.
The problem also presents itself with 5.6 and 5.5.
Can you do something?
The problem of the impossibility of listening to the phone calls has been solved.As with other GSI, it is necessary to activate the ‘disabled “option Voice Call in” Out’.
In this item we arrive with this path: ‘Settings/Phh Treblesettings/Misc features/", and then activate the’ disabled … ‘Voice Call in" Out’. …'.
Unfortunately, for the GSI 5.7 and 5.8 of iodé there are other serious problems that I explain in another post.Here the in -depth link.
