HI,
I installed the GSI Iodé 5.7 and 5.8 on a Blackview Shark8.
Two unsurpassed problems presented themselves:
In the ‘status bar’, the hour and notification icons are not placed on the left but move to the center;In addition, on the right, the percentage of the battery is not visible;
When the mobile phone goes to Wake, the screen does not turn off and the screen is subjected to continuous flash that prevent it from turning off.
My configuration is that of a mobile phone with root.
I just wanted to report these problems.The second prevents the correct use of the mobile phone.
Thanks for your work that I follow from version 1.4 and that, momentarily, I had to abandon on this mobile phone.
Emilio
