Hallo/Hello,
YouTube verlangt/required Play Dienste.
Ich hatte gesehen das es ein microG Update gab.
A microG Update was released this Week.
Wie behebe ich das?
How can I fixed this?
Vielen Dank!
Many Thanks!
Viele Liebe Grüße
Greetings
Revan335
Darkon
December 12, 2024, 12:51pm
2
Versuche am besten die Lösung wie hier vorgeschlagen für Google Maps Google Maps App can't connect to Internet - #7 by Taunite
opened 10:57AM - 11 Dec 24 UTC
**Affected app**
Name: Google Opinion Rewards, Google App, Gmail, Maps, YouTube …
Package id
`com.google.android.apps.paidtasks`
`com.google.android.gm`
`com.google.android.googlequicksearchbox`
`com.google.android.apps.maps`
`com.google.android.youtube`
**Describe the bug**
Google Apps including Opinion Rewards, Google App, Gmail, Maps, YouTube stopped working since last app update
**To Reproduce**
Steps to reproduce the behavior:
1. Install/Update Opinion Rewards with versionCode `2019049870`, Google App with versionCode `301437738`, Gmail with versionCode `64884528`, Maps with versionCode `1067838727`, YouTube with versionCode `1550046656`
2. Open affected apps
4. See error. It says that Play Services isn't installed or exit itself if installed without old previous app data, Account login function also does not work at all
**Expected behavior**
Apps should works with account, does not show any dialogues show that it doesn't have Play Services installed.
If i downgrade these affected apps to older version, it working again.
**Screenshots**
**System**
Android Version: 14
Custom ROM: LineageOS 21 : `21-20241101-microG-akari`
**microG**
microG Core version: 0.3.4.240913
microG Self-Check results: All ticked
**Additional context**
This might also affects to more Google apps in future
Diskussion on Github!
Post des Developers [com.google.android.apps.paidtasks] Google Opinion Rewards, YouTube and other Google apps started stop working with microG · Issue #2680 · microg/GmsCore · GitHub
Wie bekommt man den die alten App Versionen bzw. dessen Nummern?
Darkon
December 12, 2024, 1:29pm
5
Weiß Ich nicht. Kannst Ja dort Mal fragen
Eine Alternative könnte auch NewPipe bzw. der Fork Tubular (mit SponsorBlock) sein
Pierce
December 12, 2024, 3:24pm
7
LibreTube gibts auch noch eh alles besser als die orginal App!
Patch ist verfügbar im Thread und müsste nur noch ins ROM integriert werden.
Patch available for integration in the ROM.
**Affected app**
Package id
**To Reproduce**
**Screenshots**
**System**
Android Version: 14
**microG**
And submitted to LOS:
**Affected app**
Package id
**To Reproduce**
**Screenshots**
**System**
Android Version: 14
**microG**
Soweit bin ich leider noch nicht.
Ich bräuchte eine Alternative die Abos, Playlisten, Sync auf Handy/Tab/TV kann. Am besten mit import der vorhandenen. Ggf. noch Kommentar Funktion. Ich denke Playsettings wie Speed, Untertitel, Translate, Qualität, Teilen … sind in allen Alternativen vorhanden?
Pierce
December 13, 2024, 7:02am
10
Abos und Playlisten gibts in newpipe auch aber kein sync dafür.
Newpipe versucht das tracking einzuschränken läd daher nur die videos nutzt keinen account. Kommentare sind daher auch nicht möglich.
Ist auch selten das ich einen schreibe. Lesen eher. Wäre also eher Nice to have. Das andere ist natürlich doof. Vielleicht gibt es eine andere Alternative die vielleicht mehr kann.
Pierce
December 13, 2024, 9:07am
12
Kommentare lesen kannst du auch auf Newpipe. Ich nutze Newpipe auf dem Handy und auch gerootetem Fire TV (da ist einige Sachen aber nur über eine Maus einstallbar)
Aber vielleicht ist LibreTube auch besser da kann man zumindest Abos aus Youtube importieren. LibreTube nutze ich aber selbst nicht daher kann ich dazu selbst nicht mehr sagen. LibreTube
Dabbler
December 13, 2024, 12:44pm
13
Du könntest YouTube auch einfach im Browser verwenden. Mit ublock origin ist es sogar werbefrei.
M6s
December 15, 2024, 5:52pm
14
Ich möchte auf Google-Produkte (YouTube Premium, etc.) auch nicht komplett verzichten. Deshalb habe ich einen zweiten Browser installiert, in dem ich meine Google-Session habe. Fennec aus F-Droid mit dem Addon “Videowiedergabe im Hintergrund”, Akkunutzung “nicht optimiert” in den Android-Einstellungen. YouTube kann man sich auf den Startbildschirm legen über das Menü in Fennec.
