Xiaomi Redmi Note 9S codename Miatoll
Hi .i have installed latest 21 lineage os on my xiaomi redmi note 9s. Is there any chance that i can install iode in it .
If it is not supported by ROM you can check the GSI
here you can find instructions for the GSI: What are GSIs and how to install them? - iodé
you can check if it is treble compatible if this adb command returns true:
adb shell getprop ro.treble.enabled
if you get it working, please let us know in this thread:
(Editable list) GSI support
Busy for some weeks but i will let you know when I try it
