X/Twitter on IdeoOS 7.1
I have my Pixel 6a happily running IodeOS 6.9 with the X/Twitter application.
I have a new phone, Pixel 7, and installed IodeOS 7.1. I simply used the standard Linux installer app to do this, and if there is any special step required (e.g. per the recent announcement), I did not do that. Everything seems to be working… except
I’ve installed the X/Twitter app via Aurora Store. I know the user name and password precisely. I can access the account both via desktop browser and the Pixel 6a.
Attempting to login w/ the user name and password, I get an error LoginError.AttestationDenied
I turned to an AI thingy (GLM 4.7, rather than ChatGPT or Claude). It hallucinated a couple of things about the version numbers. It decided that the fix involved configuring microG to generate a valid “attestation.”
It told me to install “Play Integrity API Checker” app from F-Droid or GitHub. This app is not listed on F-Droid.
It also suggested looking in the microG settings - but I am unable to find where those settings would be.
I took my same question to ChatGPT and got approximately the same answer but with fewer hallucinations.
It suggested:
Option 2: MicroG / Play Integrity spoofing (limited success)
Some users try:
  • microG
  • Play Integrity Fix modules
Reality check:
  • Pixel 7+ usually still fails STRONG_INTEGRITY
  • X requires strong integrity, not just basic
  • Success rate is low and unstable
And, it suggested setting up Twitter as a PWA app
I was able to use the IdeoOS browser to Add “X” to the home screen as a PWA app, and then to login correctly. I dunno yet whether all the features work.
I’m still curious as for the other ideas, with any kind of microG settings or whatnot.
You use Twi-X and bother with a privacy conscious ROM such as iode? Cognitive dissonance?
Please, let’s not judge other people for their decisions, their mileage will vary.
@robogeek , I can’t assist, since I do not use Twitter (stopped using it 2013, since it ate too much of my time).
Did you let the installer lock the bootloader when it finished? That seems to be something that apps that need strong integrity look for.
Yes, I did do that
It is correct that microG does not support STRONG_INTEGRITY.
This said, in Plexus I see reports as recent as 2025-Dec-1 with iodéOS 6.x that give X a “Gold Rating” for X version 11.42.
