As a new member looking at the Board I see the # of posts by phone model ranked as
Samsung S10 (23)
Terracube 2E (15)
Fairphone 4 (14)
Samsung S9 (14)
Sony XZ3 (12)
Samsung Note 9 (7)
Sony XZ1 (7)
Fairphone 3 (6)
Samsung A5 (5)
Samsung Note 10 (3)
This might suggest which attract the most discussion because of the most problems they have.
Pixel not featured nor OnePlus and Xiaomi. What does that say?
Is there a way on the community forum of setting up a voting or survey post?
Yeah, very subjective. I would think that the phones iode sells with the OS would be top of the list… I mean anytime you can buy a device with a supported OS, you should be good…
BUT… I did buy a Fairphone 4 from Murena and that was a $**! show… LOL It runs better with iode… as Chrlie Browns teacher would say… Wah wa wa… lol
From what I see… The Google Pixel phones are at the front though not listed in your list. I have two iode phones - both are Pixel 7 Pro - and they run the OS very well. There are some functions on some apps that have problems but some of that is caused by me not signing into an account for privacy purposes.
