Today I found that there is a new update released to my samsung s9, but when i push download in the app i get an error message printed to check ny internet connection and try again later. I was able to download the update (.zip) from github but the size differ from the updater version (github aprox 850mb, updater 0,97 gb).
Should I try to download the update later due to some error that will be fixed or should I flash the .zip from the recovery myself? At last, any ideas why the size differs between the two versions, the updater do not use .zip format?
Thanks for a good OS and all the work you guys do.
