Unofficial Iodé builds for Sony devices
Something like waiting for Godot :wink:
Godot knows how many XA2 users.
No. I’m sure that a fix for the WiFi bug will actually arrive :wink:
April, April :laughing:
Dear petefoth,
I am looking for 5.x build for xz2c. But it seems that the 5.x and 6.x builds for almost all of unoficially supported devices are not available anymore on <link removed>
Could you please inform where 5.x builds can be downloaded?
Thanks a lot in advance!
Sorry, but we don’t keep builds made for older Android versions once the device is supported at a new Android version. Builds for xz2c have been Iodé 6 (Android 14) for quite a while now. If you need access to the latest Iodé 6 build (iode-6.9-20251117-xz2c), let me know and I will make it available to you
Dear petefoth,
Thanks for a fast reply!
I would be grateful if you could make the latest 6.x build for xz2c available for me.
I’m looking forward to it and hope there will be one more Iode OS user this evening!
By the way: I’ve been using the Iode OS for Sony XA2 for two years and it works great, except for a couple of bugs that I would be happy to report.
Done: download this zip file from Google Drive. Unzip it and you should have all the files you need (and more) to install build iode-6.9-20251117-xz2c.
Please let me know when you are done, so I can free up the space.
Good luck!
Dear petefoth,
The build has been downloaded. You may free up the space.
Thank you and best regards.
