Unofficial Iodé 2 builds for Sony Xperia Z3 family devices
You could try, but I would be very surprised if it worked :slight_smile: You’d probably have to format data - or reinstall IodéOS - to get the device booting again
non of the links work, I need z3tcw please, thanks
Unfortunately, AndroidFileHost where those old builds were seems to be broken. The last build I made for this device was in September 2023, so it is very outdated, and i have no idea whether it will work. As I stated in an earlier post
I really wouldn’t recommend using such an old build: it would be better to use the latest LIneageOS for microG build from here (which should be getting an update later this month). If you really must have the last iodéOS build, then you can find it here, but I really wouldn’t expect it to work well if it works at all.
