[UNOFFICIAL BUILDS] Samsung Galaxy S23 / S23+ / S23 Ultra
Additional note.
The problem does NOT appears when a Whatsapp call comes in.
A Whatsapp incoing call rings normally
Maybe I have simply to wait for an angel who likes “coffee” to make the 7.6 available so I can upgrade rather than downgrade :grinning_face: –Update -
@ronnz98 , Hi Ronald my young son has start fiddling with Android and he pulled this report out of the phone with adb. It is from the bluethooth log. I do not know if this might help clarifying the issue.
  1. START OF THE CALL & BLUETOOTH HANDSHAKE TIMELINE
06-18 19:20:43.279 2239 3386 I Telecom : InCallController: Calling onAvailableCallEndpointsChanged
06-18 19:20:43.279 2239 3386 I Telecom : InCallController: Calling onCallEndpointChanged
06-18 19:20:43.279 2239 3386 I Telecom : CallAudioRouteController: UPDATE_SYSTEM_AUDIO_ROUTE
06-18 19:20:43.279 2239 3386 I Telecom : AudioState isMuted: false, route: BLUETOOTH, activeBluetoothDevice: [XX:XX:XX:XX:65:20]
06-18 19:20:49.256 3277 3742 I BluetoothActiveDeviceManager: setActiveDevice: null, setHeadset=true, setA2dp=false
06-18 19:20:49.256 3277 3742 I BluetoothActiveDeviceManager: Setting active Headset (OpenRun by Shokz)
  1. THE AUDIO PROBLEM (FATAL ROUTING CRASH LOOP)
[EXPLANATION]: The Bluetooth stack enters a loop where it tries to initialize a normal
media stream (A2DP), but the OS rejects it repeatedly because it cannot resolve how
to run media and an active phone call concurrently over the Snapdragon audio HAL.
06-18 19:20:50.985 3277 3742 E bluetooth-a2dp: unable to start stream: call is active
06-18 19:20:50.986 1355 7863 I BTAudioProviderStub: streamStarted - SessionType=A2DP_SOFTWARE_ENCODING_DATAPATH, status=FAILURE
06-18 19:20:50.987 1355 7863 I BTAudioSessionAidl: ReportControlStatus - status=FAILURE
06-18 19:20:51.828 3277 3742 E bluetooth-a2dp: unable to start stream: call is active
06-18 19:20:51.829 1355 7863 I BTAudioHalDeviceProxyAIDL: control_result_cb: session_type=A2DP_SOFTWARE_ENCODING_DATAPATH, status=FAILURE
06-18 19:20:52.850 1355 7863 E BTAudioHalDeviceProxyAIDL: Start: session_type=A2DP_SOFTWARE_ENCODING_DATAPATH failure
06-18 19:20:52.850 1355 7863 E BTAudioHalStream: out_write: state=STANDBY failed to resume
06-18 19:20:53.668 1355 7863 W BTAudioHalDeviceProxyAIDL: control_result_cb: status=FAILURE failure for session_type=A2DP_SOFTWARE_ENCODING_DATAPATH
06-18 19:20:54.095 3277 3742 E bluetooth-a2dp: unable to start stream: call is active
06-18 19:20:54.096 1355 7863 E BTAudioHalDeviceProxyAIDL: Start: session_type=A2DP_SOFTWARE_ENCODING_DATAPATH failure
  1. END OF THE CALL TIMELINE & ROUTING TEARDOWN
06-18 19:20:49.629 2239 7798 I Telecom : CallAudioRouteController: onCommunicationDeviceChanged: previous device (AudioDeviceInfo: type: bt_sco id: 38), current device (AudioDeviceInfo: type: earpiece id: 2)
06-18 19:20:49.629 2239 7798 I Telecom : CallAudioRouteController: handleBtConnectionStateChanged: SCO connected(false) for address C0:86:B3:3A:65:20
06-18 19:20:49.629 2239 7798 I Telecom : CallAudioRouteController: Evaluating BT disconnect: isScoConnected=false, isOriginDisconnected=true
06-18 19:20:49.629 2239 7798 I Telecom : CallAudioRouteController: Enter pending route, orig=AudioRouteType=TYPE_BLUETOOTH_SCO, dest=AudioRouteType=TYPE_EARPIECE
06-18 19:20:49.629 2239 3386 I Telecom : CallAudioRouteController: Message received: EXIT_PENDING_ROUTE
06-18 19:20:49.629 1489 3296 D AudioFlinger: moveEffectChain_ll: successful move of session from Bluetooth to EarPiece thread
06-18 19:20:49.629 2239 3386 I Telecom : Event: RecordEntry TC@1: AUDIO_ROUTE, Entering audio route: AudioRoute[Type=TYPE_EARPIECE]
06-18 19:20:49.630 2239 3386 I Telecom : CallAudioRouteController: updateCallAudioState: updating call audio state to [AudioState isMuted: false, route: EARPIECE]
06-18 19:20:49.630 2239 3386 I Telecom : InCallController: Calling onAudioStateChanged, audioState: route: EARPIECE, activeBluetoothDevice: [null]
06-18 19:21:28.448 1357 3490 D vendor.qti.bluetooth@1.1-wake_lock: Release wakelock is released
06-18 19:21:35.255 1357 1357 D vendor.qti.bluetooth@1.1-ibs_handler: SerialClockVote: vote for UART CLK OFF
Try latest build please:
iode-7.6-20260619-dm1q.zip
Source and install instructions for S23:
iode-7.6-20260622-dm2q.zip
iode-7.6-20260622-dm3q.zip
Source and install instructions for S23+ and S23 Ultra:
https://xdaforums.com/t/rom-official-16-0-evolution-x-11-for-galaxy-s23-plus.4782988/
Hi Ronald, my phone is the dm2q (S23+)
I updated also S23+ ROM now
Hi Ron,
No joy with 7.6 either.
Here below the error logged.:
The last 3 lines in it puzzels me. Why HFP keeps on flipping ?
Bon, I do not know enough. Again , Whatsapp calls ring just fine.
BUG REPORT SUMMARY: BLUETOOTH SYSTEM SERVER CRASH (SIGABRT)
[SYSTEM INFO]
OS: iodéOS (Android 14/15 Base)
Process: com.android.bluetooth
Thread: gd_stack_thread (Gabeldorsche Bluetooth Stack)
[1. THE SMOKING GUN: FATAL CRASH]
The Bluetooth system server terminates unexpectedly due to a fatal abort (Signal 6) originating from the modern Android Bluetooth stack (Gabeldorsche JNI library).
Timestamp: 06-22 22:33:12.032
PID: 3944 | TID: 4118
Log Snippet:
F libc : Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 4118 (gd_stack_thread), pid 3944 (droid.bluetooth)
F DEBUG : Cmdline: com.android.bluetooth
F DEBUG : pid: 3944, tid: 4118, name: gd_stack_thread >>> com.android.bluetooth <<<
[2. DEVS: CRITICAL STACK TRACE]
The crash occurs instantly during the on_connection_complete lifecycle hook, specifically failing inside the internal logging utility (vlog). This points to a malformed log string format, an unallocated memory read, or a null pointer exception during connection event logging.
#00 pc 00000000000b03b0 /apex/com.android.runtime/lib64/bionic/libc.so (tgkill+16)
#01 pc 00000000000539c8 /apex/com.android.runtime/lib64/bionic/libc.so (abort+140)
#02 pc 00000000006734d4 /apex/com.android.btservices/lib64/libbluetooth_jni.so (/* error handling/abort code */)
#03 pc 000000000030eb9c /apex/com.android.btservices/lib64/libbluetooth_jni.so (bluetooth::log_internal::vlog(…) + …)
#04 pc 0000000000632a90 /apex/com.android.btservices/lib64/libbluetooth_jni.so (on_connection_complete(…) + …)
[3. SYSTEM CONSEQUENCE: AUDIO ROUTING LOOP]
Post-crash, the Bluetooth daemon attempts to recover, resulting in a cascading loop with the paired device (MAC: 3C:B0:ED:EE:89:37). The audio system gets stuck in a continuous loop trying to re-initialize profiles and resetting volume indices to 0.
Key Symptoms in Log:
  • HFP (Hands-Free Profile) constantly flipping states:
    State 3 (Connecting) → State 0 (Disconnected) → State 2 (Connected) → Repeat.
  • AudioVolumeChangeHandler flooding:
    “onVolumeGroupChanged: group: 5, volumeIndex: 0” repeating indefinitely.
  • Result: Media audio cuts out entirely or aggressively oscillates between device and phone speakers.
