[UNOFFICIAL BUILD] Samsung Galaxy S20 FE (r8q) Snapdragon! for iode 7.x
Samsung Galaxy S20 FE (r8q) Snapdragon! for iode 7.1
Supported devices:
Samsung Galaxy S20 FE SM-G780G
Samsung Galaxy S20 FE 5G SM-G781B
Do not flash on Exynos models!
iode-7.1-20251227-r8q.zip
Please see sources and install instructions including recovery here:
Use it at your own risk!
Please support the developer(s)!
Hi Ron, without the exact version of iodé recovery is not possible to install the Rom. Have you this recovery? Or, in alternative:
  1. is it possible, after extract recovery from this Rom, to install it?
  2. is it possible to install this Rom with TWRP recovery?
I think @ronnz98 typically recommends users install the LineageOS recovery and use it, did you try that?
Please note that this iodéOS 7.1 ROM by @ronnz98 is from 12/2025 and, to the best of my knowledge, has not been tested … (!)
The iodéOS Recovery recovery.img can be extracted from the iode-7.1-20251227-r8q.zip file. However, there is no vbmeta.img file … (!!)
To reduce the risk of installing iodéOS ROM by @ronnz98, I would first perform a full LineageOS A16 installation. The ROM releases from LineageOS 23.2 (A16) and LineageOS-for-Microg 23.2 (A16) include a vbmeta.img file.
After performing a clean install of LineageOS 23.2, you can try installing using command adb -d sideload iode-7.1-20251227-r8q.zip This will overwrite the LOS-Recovery with the iodéOS-Recovery.
I’m keeping my fingers crossed that the experiment will be a success.
Could not build for iode 7.5 due to kernel errors
