[UNOFFICIAL BUILD] Motorola Moto G34/G45 5G (fogos) for iode 7.x
Motorola Moto G34/G45 5G (fogos) for iode 7.1
iode-7.1-20251230-fogos.zip
Please see sources and install instructions including recovery here:
This device is officially supported by LineageOS.
Use it at your own risk!
Please support the developer(s)!
Did try to install but didn’t work. I have the newest LineageOS installed.
“ERROR: recovery: Denying OTA because it’ SPL downgrade”
edit: will try to downgrade boot.img, dtbo.img and vendor_boot.img to the version of lineage-23.0-20251220-nightly-fogos-signed.zip did work
edit2: this was the oldest files available or are there older files also hosted from LineageOS
por favor ayudame a instalar paso a paso
Suivez les instructions d’installation de LineageOS. Il est important d’utiliser la version de récupération la plus ancienne disponible, à savoir boot.img.
Sinon, suivez simplement les instructions de LineageOS indiquées dans le lien ci-dessus.
Hiiii, recently had a problem and would like to reinstall but that version is not available on LOS, I don’t know how to find oldest files, do you have those ? and could you share those with me if it’s possible, thaaanks
u could try /e/OS community fogos download the recovery from /e/OS
boot.img from lineageOS
hope the hoster work?
I have just uploaded fogos and fogo v7.2 builds to the LineageOS for microG download server: https://iode.lineage.microg.org. These builds include all the extra .img as well (boot, vendor_boot, dtbo, etc.). These unofficial builds will receive OTA updates from me as well.
omGGGG thanks a lot off u’re amazZZIng
I just updated both fogos and fogo to v7.3:
Moto G (2024) and Moto G34/G45 Unofficial Builds
From here on out I’ll quit hijacking @ronnz98’s thread :slight_smile:
Hello, How do I use the eSIM on the Moto G34?
I have found that for my unofficial iodé builds that OpenEUICC isn’t installed by default. So the stock AOSP way from Google to install eSIMs is still used. If you go to “System Settings > Network & internet > SIMs” then you can add it that way I believe.
