[UNOFFICIAL BUILD] Motorola Moto G34/G45 5G (fogos) for iode 6.x
Motorola Moto G34/G45 5G (fogos) for iode 6.6
iode-6.6-20250803-fogos.zip
https://sourceforge.net/projects/eosbuildsronnz98/files/OtherCustomROMS/iode-6.6-20250803-fogos.zip/download
Please see sources and install instructions including recovery here:
This device is officially supported by LineageOS.
Use it at your own risk!
Please support the developer(s)!
This is great. Hopefully will become official :slight_smile:
I would love to install iode on that device too. Great hardware
Hiiii, there’s a way to use it nowadays, the boot image recquired is the 20250803 but I cannot find it, do you have a way to install now or something ? Thaaanks
Update for iode 6.9:
iode-6.9-20251116-fogos.zip
how can I flash it? it shows “ERROR: recovery: Denying OTA because it’ SPL downgrade Install completed with status 1. Installation aborted.”
nvm I got it, i loveeee youuu
ayoooo, a question, does it support the bootloader relocking ? and do you have any platform for donate and thank you for ur work?, is amazing and while CalyxOS is back and as IodéOS is not offical build for moto g34 5g what you do is a blessed miracle THANKSSS
if you like to support my work:
https://buymeacoffee.com/ronnz98
i have the same error. how did u solve it?
Hiiii, in my case I followed the LOS instructions, flashing the .img of dbto and verdo_boot from the official repository of LOS, but for the recovery you need to download and flash the one from /e/OS not LOS, and finally flash the zip of IodéOS, that now he has released the 7.1, awesome
Link for dbto and vendor_bot: https://download.lineageos.org/devices/fogos/builds
Link for the recovery necessary: https://images.ecloud.global/community/fogos/
Thanks for the response. I did flash iodeOS 7.1 with the oldest available LOS recovery, and that worked. I also downgraded dbto and vendor_bot, but I’m not sure if that’s important.
However, a working recovery should probably be provided with the ROM. With the new LOS recovery, dbto and vendor_bot i was not able to flash any of the IodeOS Roms provided for the G34.
tbh, I’m not an expert on this, I’m pretty new, but the dbto and vendor_boot can be flashed the newest available, only the recovery should be the same date or older than the zip available, I just prefer flash the most recent dbto and v_b
