iode-6.1-20250328-tangorpro.zip
Source and install instructions:
Nice to have a tablet build, I know some people will be interested in this. I was considering making one but happy for you to have beat me to it!
I coordinated with @ronnz98 to post his Pixel builds to the “Unofficial builds for Google Pixel devices” thread, so check there for any updates. The top post is an editable wiki, so if any other unofficial Pixel builds are made, post them there as well!
Suggestion
The ROM designation “unofficial” does not evoke any positive associations for me at first glance. I know from experience that “unofficial” CustomROMs do not have to be of lower quality than ‘official’ stable ones, but it would reduce the inhibition threshold to use them for the first time if the list included an item such as “Functionality tested” or “Functionality untested”.
Most of the unofficial build publicised in these forums are “Functionality untested”, because the builders do not have
EDIT:
Also, I don’t know how much testing gets done, even on official builds. I don’t believe the Iodé team have the resources to do proper functional testing for every build on every device that they make or publish. When I worked for Ericsson and Sony Ericsson making Symbian smartphones (1998-2008) they had a testing team of around 30 engineers. mostly doing testing on a very small number of devices at any one time. I believe that the Iodé team is nowhere near that size ![]()
these ROMs are unofficial and should remain named as such
What should be does not necessarily have to be.
Neither iode .tech nor lineageos .org label their builds “official”.
The /e/OS is different: here there are /e/OS “official” and “commuity” builds
The positive form “official” vs positive form of “unoffical” could be e.g. “private” or “personal” or …
Since this list is editable, community members could contribute their experience with the respective builds and change the status from “xxx” or “No!”, for example:
|Device | iodéOS / Android / LOS version | Latest iodéOS build | Porter | Tested |
|Pixel 3a sargo | v6.x / A15 / 22.1 | [6.2] | @rik | yes |
|[Pixel 3a XL bonito] | v6.x / A15 / 22.1 | [6.2]| @rik | xxx |
|Pixel 3 XL crosshatch | v6.x / A15 / 22.1 | [6.2] | @rik | yes |
For a new installation, …
For updates from previous …
The iode.tech website contains the page iodéOS official supported devices - iodé which
Plenty of references is the LineageOS Wiki pages to official and unofficial builds e.g, Frequently Asked Questions | LineageOS Wiki
That used to be “official” and “unofficial” (and “custom”), and there used to be a very clear statement of what qualified for each build type, which is the definition we continue to use for our unofficial IodéOS (and LineageOS for microG) builds : basically
That was admirably clear, and it is a shame they changed their definitions, to blur the distinction between builds made by /e/ but not fully tested, and builds made by community members. But the unofficial builds in this and other threads all qualify as ‘unofficial’ according to the definition: i.e. they are built using unmodified source code and signed with the keys of the builder.
As stated in another thread.
These builds are definitely “unofficial” … The fact that the name of the ROM zip files do not include the text “UNOFFICIAL” is a bug in the Docker image that we use for building , which I hope will be corrected soon.
I like the bug in the Docker image. And as long as the ROM builder is a trustworthy contemporary, there’s nothing wrong with signing his builds with his own keys. This is always more functional than test keys.
Hello, has anyone tried it ?
I’m very interested in using Iodé for my pixel tablet and I’d like to have some feedback if someone has tried this unofficial build.
Bonus question, would it be better to use this unofficial build or the GSI ?
Will there be limitations with either this build or the GSI compared to an official build ?
Will it be equivalent to an official build in terms of privacy/de-googling ?
Thank you in advance for your help
Take latest version from here:
Since its an official lineageOS supported device it should work well
Is there a iodeOS 7 beta for tangorpro?
Separately, can the android flash tool be used on an unofficial build? I am guessing not, because o/w there would be mention of this here, but I thought I would ask.
No, the iodé v7-staging branch of the iodé manifests haven’t been published yet which are required to produce a build. iodé 7 is set to release very soon and I suspect the manifests will be made available then as well and unofficial build production will start after that.
Thank you! However, unfortunately, it appears that I have been stuck in recovery with the cable potentially disconnected, and I am not sure how to get back to installation.
Can you not restart to fastboot / recovery again and re-try?
Thank you! I am in recovery. But I can not get adb sideload to work.
adb devices also reported nothing.
Nothing happens. I am going to try a different port/cable when I go home.
I did try going into fastboot last night, but fastboot devices came up with nothing. Should I not get the device when I do this?
Unlike linux, these things have been a black box for me, since i can not get a good idea of what is going on. I guess I am old, so I like lots of messages and warnings.
With both fastboot and adb not detecting the device then the issue is not related to Recovery, install, etc. I would highly suspect your USB cable as you also suspect.
Thank you! I decided to use a type-c cable for both ends and was able to install from recovery. HOwever, the installation was corrupt. So, for now, I went back to the bootloader and installed GrapheneOS. I really like the more failsafe way of using the webinstaller, and hope that iodeOS can come with a tool like that, also for unofficial builds, since that reduces the chances of error and necessity for interacting with the device.
Did you check the .sha256sum for the file? Maybe it was just a corrupt download?
I don’t think there are any plans to have Unofficial devices integrated into the graphical installer, sorry.
