In response to a request in another thread, I have made a build of IodéOS 5.1 for this device.
It’s available from sourceforge
I do not own one of these devices so…
THIS BUILD HAS NOT BEEN TESTED AT ALL - USE IT ENTIRELY AT YOUR OWN RISK!
It should be possible to install the build by following the instructions for installing LineageOS https://wiki.lineageos.org/devices/DRG/install
There have been zero downloads of this file from SourceForge so, if no-one wants to use the build, I will be removing from SourceForge in the next couple of weeks, as they are hassling me about using too much space.
bonjour , vous pouvez m’envoyez kernel source svp
Désolé, mai non.
I build using the code from the LineageOS github repos. The kernel code for this device will be in one of those repos.
Bonne chance!
