Unofficial build for Nokia 6.1 (2018) `PL2`
In response to a request in another thread, I have made a build of IodéOS 5.1 for this device.
It’s available from sourceforge
I do not own one of these devices so…
THIS BUILD HAS NOT BEEN TESTED AT ALL - USE IT ENTIRELY AT YOUR OWN RISK!
It should be possible to install the build by following the instructions for installing LineageOS
https://wiki.lineageos.org/devices/PL2/install
There have been zero downloads of this file from SourceForge so, if no-one wants to use the build, I will be removing from SourceForge in the next couple of weeks, as they are hassling me about using too much space.
Edit:
Have downloaded these and will keep you posted - will spend some time on this tomorrow morning hopefully. Thanks for the opportunity to keep this Nokia running and degoogled.
I’m new to iode but would love to test this build if it’s still possible. I was searching for a de-googled option for the Nokia 6.1.
I have some experience with porting and roms. Have currently got a Pixel 3a XL running UB touch.
Are these links still available?
Thanks,
