Tunnelbear problem
I try to debug a problem with tunnelbear.
is anyone able to connect with tunnelbear app? I tried on 2 iodeos phone. No luck
Thanks in advance
Just created an account and used it on iodé. Is your problem logging in or instead activating it? Is your location possibly blocking access to it (firewall etc. preventing known / popular VPN connections)?
Activating it. And strange behavior while doing so if I close the apps and reopen it. Example: screen going blank.
There are no other problems with all the other VPNs I tried which is 9 other vpn. so it should not be that .
Iodeos 7.2 yours ? And app is 4.9.1?
Thanks you gave me an idea actually. It does not work well with custom nextdns configured I will dig that lead.
It’s ALWAYS DNS right? :slight_smile:
