I just installed iodé on my shift6mq, most apps are running fine. Only TomTom failed to install, has anybody here an idea what can be done? Many thanks for any help.
Hi mate,
I have Amigo TomTom maps working great on my device.
Is this what you are trying to use?
Hi, I try to use TotomGo with the offline maps. I assume, the problem is that this is a paid version.
I will give AmiGo a chance, thanks for the hint.
I couldn’t get TomTom to work, too. So I changed to Sygic, there premium can be bought separately on the website.
Hi, I have tested now Tomtom AmiGo, looks ok, but it always stops the navigation after 15-20 minutes. Is there anything to configure?
